Highlighted
Re: Washing machine drum filled with smoke after loud bang.
JUMP TO SOLUTION
Oh no! I definitely apologize for the inconvenience this has caused. Please send me a private message with your full serial number. http://bit.ly/2tCGnGK
Highlighted
Front load washer, loud bang and smoking
JUMP TO SOLUTION
My washer just made a super load bang while in spin cycle, found it billowing smoke i saw post but no answers
Highlighted
Re: Front load washer, loud bang and smoking
JUMP TO SOLUTION
Hey there! want to make sure if you haven't already to unplug the unit. Where is the smoke coming from? Please feel free to send me a private message with your full model and serial number? http://bit.ly/2tCGnGK
Highlighted
VRT Front Load Washer loud sound on and smoke inside
JUMP TO SOLUTION
I have a Model # WF331ANR/XAA front load washer, the washer was making unusually loud rumblng on spin cycle and I look and there was smoke inside, smells like burning rubber... scared to run this washer again.  Is this a known problem and can be fixed?
Highlighted
Re: VRT Front Load Washer loud sound on and smoke inside
JUMP TO SOLUTION
Can I have you send me your serial number via private message? I would like to get this resolved for you right away.
Highlighted
Loud Spin Cycle and smoke inside WF328AAW/XAA
JUMP TO SOLUTION
I have a Samsung washer that is now very loud on spin cycle, and smells of burning. When it finished, I opened the door and it was filled with smoke. Trying to figure out how I can go about fixing this issue.
Highlighted
Re: Loud Spin Cycle and smoke inside WF328AAW/XAA
JUMP TO SOLUTION
My sincerest apologies for the frustration and inconvenience this has caused. Please feel free to send me a private message with your serial number so that I can look into this for you. http://bit.ly/33ipYnO
Highlighted
JUMP TO SOLUTION
@SamsungBri the serial number is <hidden>
Highlighted
JUMP TO SOLUTION
@userq353qHn5MC: can you send that information via private message? Click the link ----> http://bit.ly/33ipYnO
Highlighted
Samsung washer WF337AAG loud noise then white smoke in the drum, burning rubber smell
JUMP TO SOLUTION
Is this just a hose or a gasket that I can replace myself?   We just moved and don't want to call a repairman!
