Highlighted
Re: Samsung VRT Front Loading Washer Loud Sound and Full of Smoke
JUMP TO SOLUTION
We are so sorry to hear about this. Please send the serial number for the washing machine to this PM Link, and we will look in to this for you.
Highlighted
JUMP TO SOLUTION
My washer just made a very loud noise with 2 minutes left on wash load - it finished - then the load finished and I opened the drum door to a cloud of smoke and terrible burning smell.  This appears to be a common problem based on others on this site experiencing the same.  And a rather serious fire hazard.  Can someone from Samsung please provide contact me with a solution?    Or anyone else on this site who have learned anything more about this.  Thank you!
Highlighted
JUMP TO SOLUTION
Can you send me a private message with the full model and serial number of the washer?
Highlighted
JUMP TO SOLUTION
We had a similar issue today.  When the washer was running, it sounded louder than normal.  Then, I started smelling something burnt, so I went downstairs to check the washing machine.  There was smoke swirling in it.  I stopped the cycle and smoke poured out.  The clothes all smell and there are hard small rubber pieces on the laundry.  What should we do?
Highlighted
JUMP TO SOLUTION
My Samsung just did the same thing!!!! The whole basement is filled with smoke. I closed the door to keep the alarms from going off. Why is this happening? I see so many other people this happening to. This just seems so dangerous.
Highlighted
JUMP TO SOLUTION
I'm sorry to hear that, so that I may look into this can you send me a private message with your full model and serial number?
Highlighted
Wf448AAP/XAA 04 burning smell and smoke
JUMP TO SOLUTION
Washing machine started making loud baging noises, got stuck on a spin cycle and wouldn't turn off - and then I smelled burning plastic/rubber, and got smoke.
Is this a belt or something I can fix myself, without having to call someone?
Highlighted
Re: Wf448AAP/XAA 04 burning smell and smoke
JUMP TO SOLUTION
We are sorry to hear about this. Please send the serial number to this PM Link, and we will look in to this.
Highlighted
Re: Front Load Washer: Bang! and then smoke
JUMP TO SOLUTION
Just had the same thing happen to my washer, loud bang, lots of noise and nasty smelling smoke filled the house.
Model: WF328AAW/XAA
Highlighted
JUMP TO SOLUTION
I'm sorry that you are experiencing this. Can you send me a private message with your serial number? http://bit.ly/2tCGnGK
