Front load washer Model WW22K6800AW/A2 won’t complete cycle
(Topic created: 05-21-2025 03:25 PM)
DeeDeeMae
Washers and Dryers
washing machine did not complete cycle and no error codes, displayed remaining time but was stopped.  Unloaded clothes and cleaned filter, attempted to finish cycle empty.  Machine won’t stay it spin cycle, attempts but only moves a few inches or rotations then stops
GaryB82
Galactic Samsung Care Ambassador
Washers and Dryers
I recommend contacting Support and requesting a technical diagnosis for the issue you are experiencing with your washer. The cause of this problem could be anything.
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
realaud
Honored Contributor
Washers and Dryers
May I suggest that you check the outlet that the machine is plugged into?  I had a washing machine once that did the same thing so, being that it had a good life, I went out and replaced it only to find out that it was the outlet that was bad.  There was enough power running to the outlet to power the lights and the start of the cycle, but not enough to power through completion (which is why I was fooled into thinking the washer was at fault).  It wasn't that it tripped the breaker either, it just stopped.  Once the outlet was replaced, everything was good.
