- Mute
- Email to a Friend
12-27-2016 11:50 AM in
Washers and DryersThe words on my front load washer are smearing so badly that I can't read some of thme. I believe I need a new panel. Is this a problem that has happened before? I believe it should be covered under warranty. How can I get this fixed?
Solved! Go to Solution.
- Mute
- Email to a Friend
09-01-2020 05:39 PM in
Washers and Dryers@user3mK0rmSJTY We are sorry to hear about this. Please send a picture of the panel lettering, along with the full model and serial numbers, to this PM Link.
- Mute
- Email to a Friend
09-01-2020 08:09 PM in
Washers and Dryersso what are some methods to preven this from happening?
received a new washer today
there some protective film that can be applied?
- Mute
- Email to a Friend
09-02-2020 12:27 PM in
Washers and DryersThis will require service. If you are located in the US and the unit is within the 1-year warranty the service will be covered under the warranty.
If the unit is out of warranty, you can use the following link below to request service or contact our phone support line at 1-800-Samsung to have service set up for you:
https://www.samsung.com/us/support/service/
If the unit is not a US model, please seek a support team for your area. You can do so by using this link: http://www.samsung.com/visitcountry
- Mute
- Email to a Friend
09-18-2020 09:57 AM in
Washers and DryersA service tech came out to replace the front panel and the part with the lettering was not there. Tech ordered new front panel and will return once it arrives.
- Mute
- Email to a Friend
09-21-2020 05:50 PM in
Washers and DryersJust bought this front loading washer for $799 from a local store. The writing is coming off the control panel about a month later. Crazy and totally dissatisfied with Samsung's response. They do not cover "cosmetic" repairs. So ridiculous to pay that much money and have it so poorly made. DONT BUY THIS
- Mute
- Email to a Friend
01-09-2021 01:32 PM in
Washers and DryersLetters are rubbing off
Lettering starting to wipeoff on Dryer also
Washer. Also smudging on this same lettering on Dryer
- Mute
- Email to a Friend
01-09-2021 01:18 PM in
Washers and DryersThe words for the washer dial settings wipe off. I noticed this when I got the washer March 2019, but didn't make a big deal, but it's getting worse. I am happy to share photos and any additional details you may need.
- Mute
- Email to a Friend
02-08-2021 06:21 PM in
Washers and DryersApparently this comment is all too true: "If you are located in the US". I have this problem with my 8 month old washer and contacted Samsung support in Canada. I was told this was considered a "maintenance issue" and was not covered by the warranty. I don't know, letters wearing off within 8 months of normal use sounds like a manufacturing defect to me. I guess I'm out of luck because Samsung only values US customers.
- Mute
- Email to a Friend
03-02-2021 04:41 AM in
Washers and DryersDisappointed with the quality of a laundry product that would have what Samsung deems a “cosmetic defects” within less than a year from touching or cleaning the control panel with a dry cloth. I was insulted by a recommendation from the Samsung rep to print a template of the labels from the manual and tape it on the washer so I would know where each wash setting is. My daughter and best friend both have the same washer—one purchased before me and one after, yet neither have this issue. My daughter wipes hers down with Clorox wipes and her labels don’t smear or wipe off. Yet, I literally cannot touch the area with the control labels with my dry hands for fear of further smearing. I had a whirlpool duvet washer and dryer for 12 years and the labels did not smear off. BTW, the Samsung dryer labels are intact. Go figure.
- Mute
- Email to a Friend
07-17-2021 11:01 AM in
Washers and DryersWasher 1 year out of warranty and lettering smearing off. This was an expensive product. It’s only two of us so maybe two loads a week. That is 200 loads and the lettering is coming off. How can I get this repaired?
