Front load washer control panel words are smearing
(Topic created: 12-27-2016 11:50 AM)
userKEkzEgAPKo
Washers and Dryers
The words on my front load washer are smearing so badly that I can't read some of thme. I believe I need a new panel.  Is this a problem that has happened before? I believe it should be covered under warranty. How can I get this fixed?
JUMP TO SOLUTION
Samsung_Jdx0xct
Washers and Dryers
SamsungAl
Washers and Dryers
This is going to require service. You can use the following link to locate a service center near you:https://www.samsung.com/us/support/service/locations/.
useroL1SYY5Eca
Washers and Dryers
so how much to service an out of warranty washer for this problem of soluble ink?  Seems like a big design flaw for something that is going to come into contact with detergent, wet clothes, and stain remover on a weekly basis.  Mine is the same model as the one above and my whole left side is smeared because I wiped up stain remover overspray immediately after it happened.  First time I've ever bought a washer brand new and I'm upset that the 30yr old hand me downs never had this problem but your unit does.
user3mK0rmSJTY
Washers and Dryers
What I thought was dirt on my washer and when I wiped it off turned out to be the lettering around the control knob smeared.20200826_155329.jpg
userTFQeHrP0ey
Washers and Dryers
v try to make a phone call
user3mK0rmSJTY
Washers and Dryers
Who do you suggest I call?
user3mK0rmSJTY
Washers and Dryers
I have not called anybody. I went to Samsung website and did a chat session.
Should I have called somebody, If so what is the number?
user3mK0rmSJTY
Washers and Dryers
Just got off a chat session with Samsung and they advised it was cosmetic and was not covered under warranty. This unit was purchased in March 2020 5 months old and ink on the control panel smears
user3mK0rmSJTY
Washers and Dryers
Not sure if this was caused by the Costco ECO laundry soap or the Downy softner. My wife bought powered bleach so I know it was not caused by the bleach getting on the lettering. You would think that the ink they use would standup to laundry soap and or softner.
user3mK0rmSJTY
Washers and Dryers
This issue still has not been resolved. Is there some replacement lettering that can be purchased if it is not going to be covered under warranty on a 4 month old washer.
