Front load washer control panel words are smearing
(Topic created: 12-27-2016 11:50 AM)
userKEkzEgAPKo
Washers and Dryers
The words on my front load washer are smearing so badly that I can't read some of thme. I believe I need a new panel.  Is this a problem that has happened before? I believe it should be covered under warranty. How can I get this fixed?
JUMP TO SOLUTION
Herkfixer
Washers and Dryers
I have a Samsung washer and dryer that are less than 1 year old (WF45R6300AW) and the letters are coming off the cycle names around the selector dial. Is this covered under the man. warranty? They come off with even the slightest rubbing with a clean and dry cloth (trying to merely wipe clean as part of regular cleaning).
SamsungCaleb
Washers and Dryers
Hello! I understand how this can be frustrating with your washer letters coming off, so that I may look into this further can you send me a private message with your full model and serial number?
usergDVtwqLjvz
Washers and Dryers
Good afternoon, our front loader machine has the words for the cycles smearing. Can this be fixed or overlay purchased. It looks terrible.
Model bubble wash front loader
<HIDDEN>
SamsungTam
Washers and Dryers
Hello! I do completely understand your frustration with the washer lettering smearing I'll be more than delighted to assist with this issue. Do you use anything to wipe the machine down? Also, can you send me a private message with pictures of the symptoms you're experiencing as well as the full model and serial number? http://bit.ly/2tCGnGK
userFNzT6Qy3gd
Washers and Dryers
Hi all, I purchased my front loader washing machine in July 2020 and a few months ago the words starting rubbing off the dial. It wasn't anything major, but now I've lost half the words. I can't tell which setting to pick as it's impossible to read the words. Can someone help me out?
Thanks
Paulina
MsBri1
Neutron Star
Washers and Dryers
Hello, I'm terribly sorry to hear about this experience, and can definitely understand your frustration. It sounds like you may have a case that will require more of a one of one review and possible back and forth communication. So that we can look further into this case. Can you please send us a private message- https://bit.ly/3p4UuiW with your model code and serial number so we can look into this further for you?
usercburc92jCi
Washers and Dryers
The words on my front load washer are smearing and I’ve had the washer barely a year. I can literally rub the words off with my finger. And I mean gently touching them with no force at all. I noticed one letter appeared to have something on it and I went to wipe it off. When I rubbed it, off came the entire word just about. It wasn’t damp, wet or anything. Is this a problem that has happened before? I believe it should be covered under warranty. How can I get this fixed?
Samsung_Moderator
Washers and Dryers
Hello! I understand how this can be frustrating with your washer letters coming off, so that I may look further into this can I have your full model and serial number and a picture of your washer in a private message?
usercrPHVrs0wE
Washers and Dryers
The words on my front load washer are smearing.  I can literally rub the words off with my finger. And I mean gently touching them with no force at all.  It wasn’t damp, wet or anything. How can I get this fixed?
Roxanne55
Galaxy
Washers and Dryers
What kind of weird thing is that? Is it an actual Samsung product.
