Catlover3621
He top loading washer uses hot washer on Delicate cycle
JUMP TO SOLUTION
My Delicate cycle uses hot water instead of the cool water it’s set up to use. I have no problem selecting cool/cold on other cycle selections .  Delicate Cycle is set up so you can’t select a different temperature even if you wanted to!  How in the world is it using hot water?
Model #WA52M7750A
any ideas/solution for this ?
thanks
1 SOLUTION
Re: He top loading washer uses hot washer on Delicate cycle
JUMP TO SOLUTION
I apologize here is the link.
4 REPLIES 4
JUMP TO SOLUTION
Hey, give this link a shot. It should help. If not, the unit may require service.
Catlover3621
JUMP TO SOLUTION
I don’t see a link?
JUMP TO SOLUTION
Catlover3621
JUMP TO SOLUTION
Thanks, it’s working correctly now
