- Mute
- Email to a Friend
09-12-2020 04:39 PM in
Washers and DryersHi everybody,
I just bought a used Samsung dryer and i just realized that i can barelly see the Display screen.
M'y question is, is There a Quick fix or do i have to replace the Hole screen to make it work ?
If you need more info about the machine please let me know.
Thank a lot for you're help
Alex
Solved! Go to Solution.
- Mute
- Email to a Friend
09-12-2020 06:38 PM in
Washers and DryersI would verify that enough voltage is being put out via the outlet you've got the dryer plugged into. For Electric dryers, the voltage required is 240V and for gas, it's 120V. If the outlet is letting out enough voltage, it's possible that the dryer control panel needs to be replaced and you can use the following link to locate a service center near you: https://www.samsung.com/us/support/service/locations/
- Mute
- Email to a Friend
- Mute
- Email to a Friend
09-15-2020 06:46 AM in
Washers and DryersHi, thank you for you answer. Yes the voltage is with a 240 volt. Ok thank you i'll follow the link you gave me. I Will Do the repaire myself tho.
Have a Nice day
- Mute
- Email to a Friend
09-15-2020 09:13 AM in
Washers and DryersYou are very welcome!
- Mute
- Email to a Friend
09-17-2020 05:58 AM in
Washers and DryersActually, i'd like to verify something with you again.
I tryed the machine a couple of Time now and i'm realizing the problem is bigger than i tought. First thing i saw was the led light faded. Now i See that the Power button is not answering well. I'm wondering that is the part that i have to change ? Is it the control panel ? Or something else ? I Found that those part cost more than 150$, i don't want to replace something for nothing at this Price.
Thank's a lot
- Mute
- Email to a Friend
09-17-2020 08:01 AM in
Washers and DryersI recommend letting a service technician have a look. Send your full model code and serial number via private message or call
1-800-SAMSUNG directly to get started.
