Highlighted
My electric dryer turns off after running for a few seconds and then back on after few minutes
What is wrong ?
Is it possible to reset the control panel ?
1 REPLY 1
Highlighted
Re: My electric dryer turns off after running for a few seconds and then back on after few minutes
Have you tried to turn the unit off by the circuit breaker? Or unplug the unit for 3-4 mins?
On the inside of the dryer is a moisture sensor which looks like two metal curved bars inside the front of the drum, typically in the housing for the lint filter or to the side of it.
  • Take a damp cloth with mild soap and clean the bars
  • Try running the dryer again to see if it keeps running without turning off.
If these steps do not resolve the issue then the unit will require service. You can use the following link to find a service center near you to do the repair. http://www.samsung.com/us/support/service/location.
