Members_1jyX7lc
- Mute
04-22-2025 07:34 AM in
Washers and DryersHELP!!!!
My Samsung washer turns on, but midway through the cycle, when it's supposed to drain, it makes a strange humming sound. When I try restarting it, it powers on but still doesn't drain the water.
3Fees
Neutron Star
- Mute
04-22-2025 08:07 AM in
Washers and Dryers
Could be a clog in the drain hose like a small sock or the pump that forces water out of the drum into the drain hose is defective.
Cheers
3Fees
Cheers
3Fees
Members_1jyX7lc
- Mute
04-22-2025 08:20 AM in
Washers and DryersThank you for your reply. How do I clean it out or do I need a new hose?? This is first time this happen.
3Fees
Neutron Star
- Mute
04-22-2025 08:40 AM (Last edited 04-22-2025 08:41 AM ) in
Washers and Dryers
You'd have to take out the outer casing to inspect the internal parts. Before this unplug the unit at the wall socket.
I'd contact your Samsung service provider, he could inspect in minutes and tell you if it's a clog in the drain line or the drain motor.
Cheers
3Fees
Cheers
3Fees
