Need Part Number Rubber Foot for Flexwash Top Lid Switch
(Topic created on: 4/25/21 6:31 AM)
user0l9XydMv0g
Washers and Dryers
Hello. I went to use the top washer on my WV60M9900AV/A5 flex wash today and was met with the 1DC4 error code. I had this before and it was the actual sensor that was bad. The entire assembly was replaced after the tech broke the board. It's been working for a year since. I noticed today that somehow the rubber foot that sits inside the lip of the exterior housing of the top washer is missing. This means that the lid switch has nothing to depress it when in the closed position.
I tried to find the part number for this rubber foot on the schematic diagram but I can't find it. It won't work without this rubber foot. It must've gotten knocked loose when I took laundry out. Why this part is even removable is beyond me.
Anyone know the part number and have a picture to confirm it's the correct thing?
Thanks!
1 Reply
SamsungTam
Washers and Dryers
I recommend reaching out to our part distributor, J & J Parts, at 800-627-4368 or samsungparts.com
