Notifications for Washer/Dryer ceased function
(Topic created: 10-21-2021 06:31 AM)
ajpn
Cosmic Ray
Washers and Dryers
Does anyone know why my notifications would suddenly stop working for my washer and dryer? Smart Things is up to date and the appliances all show. But
I used to think it was annoying, but it helps when you have clothes that need to be folded immediately.
SamsungStephanie
Washers and Dryers
Hello, I would recommend creating a Support ticket so we can look into your concerns further since the app is up to date and the appliances are showing as connected. You can reach out directly to a support team in your area using the below information:
By Phone: 1-866-813-2404 or Online at: support@smartthings.com
ajpn
Cosmic Ray
Washers and Dryers
Yeah that's not going to happen. My experience with Samsung help has been useless as well as time consuming.
I uninstalled my washer and dryer from smart things, reinstalled and renamed them and it worked. Typical reliability with Samsung apps.
But thank you for the suggestion. I appreciate the effort.
ajpn
Cosmic Ray
Washers and Dryers
Solution: uninstalled the appliances from the smart things app and reinstall them. I also renamed them for good measure (Darth Dryer and Obi-wan Washer). Not sure if renaming them was necessary, but I did it anyway. This solved my issue.
SamsungStephanie
Washers and Dryers
Hello, Thank you for the update and we're pleased to see you were able to resolve your issue. We want to thank you for being a part of the Samsung Community and please do not forget to mark your solution to help others that may come upon this same issue.
