Highlighted
Our dryer is running and won't turn off
Our dryer keep spinning and won't shut off unless I open the door or unplug/cut power. This seems to be a common problem but didn't find the solution in the other posts. Please advise how we can fix this.
Thanks in advance,
Sarah
2 REPLIES 2
Highlighted
Re: Our dryer is running and won't turn off
Model No. DVE45N5300W/A3
Serial No. <HIDDEN>
Highlighted
1. Make sure that the 3-hr Air-fluff/Wrinkle Prevent option is not on.
2. Run a light load of clothing. Does it heat?
If the unit does not cut off and runs continuously unplug the unit for about 5 minutes and plug back in if it’s turning then we need more details about if the unit is heating or not.
Please send me a private message so I can look further into this for you http://bit.ly/2tCGnGK
