Re: RUST ISSUE SAMSUNG WASHER MODEL WA48H7400AW/A2
JUMP TO SOLUTION
userHD5858rDQW, please send us a private message so that we can look into this for you: Link
userYDFTHXtahP
JUMP TO SOLUTION
I'm having the same problem except right now it's just chipping in all the same spots where others have full rust. Model WA48H7400AW/A2. What options do I have, was told warranty doesn't cover. Machine bought 10/2016.
JUMP TO SOLUTION
userYDFTHXtahP, please send us a private message with the serial number: Link
JUMP TO SOLUTION
Please get that to us as soon as you can.
userfmA4UdMDZF
JUMP TO SOLUTION
I have the same issue.  Rust in the soap dispenser.  The problem is getting pretty bad.  The rust sticks to clothing and irritates the skin.
daveh2o
JUMP TO SOLUTION
I have the same rusting issue with my washer. My washer is only 2 years old and Samsung customer service told me to buy a new washer to avoid the costly repair of my washer? Obviously that is ridiculous; I’m not buying a new washer every two years. I have reluctantly decided to fix my washer so I can get another two years out it. I’m currently looking for an extended appliance warranty program (3 party) that is not a rip off and would cover such repairs. (no luck so far) The best solution is to never buy any Samsung product again.
userfV3KW9X2FW
JUMP TO SOLUTION
My previous dryer was returned under the recall and we decided to stick with Samsung for our new dryer.  In Jan 2017 we purchased model # WA45H7000AW .  15 months later and the top near the bleach dispenser is runting through.  This product is terrible
userFwD8MxYUKJ
JUMP TO SOLUTION
We purchased our Samsung Washer, same model - WA48H7400AW, 18 months ago and it is rusted too. The paint is peeling and rusting, causing clothes that touch it to be stained with rust. We were also told that it was not cover under the warranty even though this is NOT normal wear and tear.  How do we get this fixed???
userGxpluOLx9n
JUMP TO SOLUTION
I have the same rust issue with my machine model # WA48J7700AW/A2 rusting around the beach dispenser.  My machine is part of the recall but I have not had the work done.  Do you think it is possible to have the top changed when they come to do the recall work?  I would appreciate a response from the moderator.
userIsU1sFIMvp
JUMP TO SOLUTION
I have this same model and my washer is rusted. I purchased a 3yr warranty thru best buy but I wasnt aware of a recall. Please advise how I can get my washer repaired. Thank you.
