Rust stains on clothes - Using Well water
(Topic created: 06-06-2022 07:34 AM)
user4J835HTJbB
Washers and Dryers
  • I'm having trouble with rust from my well even though we have a Culligan water filter system.  When I wash whites the clothes are stained.  Had water tested and we have found that we have Iron (SM 3500 Fe-D) and also Colloidal Iron which I understand is very difficult to control due to the very small particulates passing through normal filters.  Does Samsung have a solution for this?  I seem to be running into a dead end with everything I've researched.
DanG92263
Neutron Star
Washers and Dryers
When I was married we had well water too with the highest filtering possible and still got rust stains on our clothes. Every so often my wife would run our whites through the machine with Rit White-Wash. Worked like a charm.
Rit Powder White Wash 1 7/8 Ounces https://www.amazon.com/dp/B001761JCE/ref=cm_sw_r_apan_i_RJ21BX0KFQFT2VRJEH1F
1 Reply
DanG92263
Neutron Star
Washers and Dryers
