Highlighted
Samsung DV80F5E5HGW Heat Pump Dryer
JUMP TO SOLUTION
I have Samsung DV80F5E5HGW Heat Pump Dryer. It worked perfect for 4 years. However, a dryer started indicate a full water tank sign yesterday. It happed just a first time for me, because every time I drain the tank after 1 - 3 cycles of drying. After indication started I have drained the tank. Unfortuntly, the indication started again for more 2 times. Just a glass of water was inside. An error 5E was indicated after I have started the drying again.
I had a call to local Samsung service. I was asked to clean a filter of water outlet (I am not sure where it could be). Also things I should do:
run a empty cycle
calibrate the machine
turn of the power for 10 minutes.
Does anyone had similar issues?
Regard
1 SOLUTION
Highlighted
Re: Samsung DV80F5E5HGW Heat Pump Dryer
JUMP TO SOLUTION
Hi everyone!
it was found that the particulate issued of my Samsung dryer is described in this blog:
https://mihosoft.eu/?p=246
The problem is SWITCH FLOAT.
I am thankful to the local technician that help me and to the "mihosoft" that have written down the whole issue very nicely.
2 REPLIES 2
Highlighted
JUMP TO SOLUTION
Thank you for reaching out, this support page is for US customers and models only please use the link below to find your country's support page, Thank you!
https://www.samsung.com/us/common/visitlocationsite.html
Highlighted
JUMP TO SOLUTION
Hi everyone!
