- Mute
- Email to a Friend
01-26-2021 01:09 PM in
Washers and DryersMy Samsung FlexWash lower washing machine won't power on and won't unlock door. The upper washing machine is fine.
- Mute
- Email to a Friend
01-30-2021 04:11 PM in
Washers and DryersI'm sorry to hear that, how long have you had this washer? Also, does this occur after power cycling the washer?
- Mute
- Email to a Friend
a week ago in
Washers and DryersI have the same issue for my 2-year-old washer. The washer stuck in the middle of washing process (around 50~55 minutes remaining). No response pressing any button, except the power button turned the lower washer off and never able to turn on again, door is locked. Upper washer is still working fine though.
What do you mean by “power cycling”?
- Mute
- Email to a Friend
a week ago in
Washers and DryersBy power cycling, we're asking if you have either unplugged the washer or flipped the circuit breaker off for a few minutes? Sometimes a soft reset like that can correct the issue.
