Dryer won't turn off
(Topic created: 11-13-2020 10:19 AM)
user0rDBQTmpYV
Washers and Dryers
Dryer won't stop model dv5471aew
userctOPKIBj1i
Washers and Dryers
have you tried unplugging or turning breaker off for a few moments? Mine done the same thing , it fixed it for awhile but ended having to have control board replaced.
userQ51IiRaHFg
Washers and Dryers
Yes, I have unplugged it and that didn't work. I may try unplugging it at the control board to see if that resets it. I can't get a service tech out here until the end of the week.
usertqx6WLa2o8
Washers and Dryers
Dryer runs cold and power is off to unit. Only way to stop is to open door. Bought in January of 2020, it's now Nov 2020.
userkWOHVSLNo2
Washers and Dryers
Hello I have a dryer that won't stop spinning even when the unit is "powered off". This is very concerning since the dryer is about 2 years old and we bought it new. The model is dv42h5200ew/a3
Could someone please message me and help me or give me a solution please. I've always liked samsung products but this has really deterred me from wanting more samsung products ever again. For sake my mother has had the same dryer since I was a child with no problems ever
Not applicable
Washers and Dryers
We're sorry to hear that! Please send us a private message with the full model code and serial number: Link
SSuperman
Washers and Dryers
This could be a bad timer, bad moisture sensor, etc.....because your problem could be many at the control panel area, a multimeter os needed to test each components ( process of elimination); a technician is require to perform these test.
user7wGICr4VJY
Washers and Dryers
welcome to cheap products
user7wGICr4VJY
Washers and Dryers
Pathetic, This dryer was purchased only 20 months ago, and now I have to pay 300 for repairs!  The first time I purchased a Samsung major appliance. Guess whose appliances I will not be buying for my new kitchen? What a low quality product. This issue is very common. I will be sure to give negative reviews on all the sites
usere672yMllHw
Washers and Dryers
I am not sure what to do. My dryer won't stop spinning even when turned off? It happened a cpl times b4 but I was able to get it to stop but this time I can't seem to get it to stop. Had anyone had this happen to them or something similar and if so what did you do. I am not the original purchasing person so I cant use the warranty on it & I can't afford to have someone come look at it. So anything anyone can think of to help fix this would greatly be appreciated..
MalteMicha
Halo
Washers and Dryers
What is model number of dryer? You turn it on to use and it just spins?
