Highlighted
Samsung WA45N3050AW/A4 will not drain
JUMP TO SOLUTION
I've watched videos, held down temp button to see if there is an error code and there is not. It fills with water, does the cycle but doesn not drain. I brought out the level and it is level. I cut the drain hose so only 6 inches are in the drain. I've checked the wires and connectors under the washer and all look perfect. I purchased Feb, 2019. Please assist👍
1 SOLUTION
Highlighted
Re: Samsung WA45N3050AW/A4 will not drain
JUMP TO SOLUTION
If a cycle with hot water temperature settings (such as Pure Cycle or Sanitize) was run recently, the water in the washer may be very hot. Allow approximately one hour for the water to cool before performing this procedure to avoid possible injury.
Do not remove the screw on the back of the washer that holds the drain hose against the washer. If the screw has been removed, screw it and the holder back in with any screw that fits. If the holder is missing, service is required.
  1. Turn off the washer and check the level.
    If the washer isn't level it may not drain correctly. Make sure your washer is level.
  2. Inspect the drain hose.
    Incorrect drain hose installation is the most common reason for drain issues, and service is rarely required. For more information, the full installation instructions are available in the user manual.
    Verify the drain hose:
    • Is not inserted more than 6 inches and less than 8 inches into the standpipe or sink
    • Is secured so it will not slip down farther
    • Does not form an airtight connection
    • Is not kinked, bent, or damaged
    • Is at least 18 inches high (24 inches for wash basins)
    • Is not higher than 96 inches (35 inches for wash basins)
    • Is not using a drain hose extension kit
    Washer inspect the drain hose
  3. Clean the pump filter (front loaders only).
    Clean the pump filter periodically to improve cleaning performance and help prevent odors. A clogged debris filter reduces the effectiveness of the draining system.
  4. Turn the washer back on and start a cycle.
    The washer should drain at the beginning of the test cycle. If it does not, this will require service.
If the troubleshooting steps did not help above then you have a couple of options based on your warranty.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
is that a smart washing machine
Highlighted
JUMP TO SOLUTION
Yes. It is.
Highlighted
JUMP TO SOLUTION
