Samsung Washer Thudding Sound on Spin Cycle
(Topic created: 12-25-2024 02:23 PM)
vintage_siam
Washers and Dryers
Hey all,
Any thoughts on the possible reason behind this sound my washer started making?
<REMOVED>
Thank you!
j_hnny
Washers and Dryers
This is happening to my machine too, it's brand new, not a month old yet. any updates?
vintage_siam
Washers and Dryers
Hey mate,
Sorry to hear that. My machine is over three years old, so you may have a defective unit. I suggest you use the warranty on your machine to replace it. That said, I did call a repairman to my home to run a diagnostic test on my machine and he said it is caused by overloading the washer. Over time, the balancing joints and/or belt wear down and even break.
As such, I took out a warranty with Puls since I am outside of the warranty period with Samsung and will probably end up replacing the unit as it costs over $800 USD to replace the balancing joints and/or belt with labor. Just the cost of doing business, I guess.
I hope this helps!
