Samsung Washer #WA45H70000AW/A2 continuous uneven load then rinse and spin
(Topic created on: 3/30/21 1:59 PM)
userZk2TFjmlyf
Washers and Dryers
This problem has been getting worse as time goes on. Now almost every load results in and uneven load error, then the washer cycles through another rinse cycle.  This goes on for hours.  I would normally stop the load, power off, and run a spin cycle only.  This no longer works.  I have already had to replace an internal rotted out plastic tube, which had began leaking.  The unit is about 6 years old, but I expected more from Samsung.  We also have a Samsung Dryer which has failed twice in less than 5 years due to faulty rollers.
