usernD5530I3oB
Samsung White Front Load Steam Washer - WF45R6300AW
anyone else experiencing . . .
a fair amount of water sitting in the gasket after washing like 1/4 cup or 1/2 cup on some loads.
It seems the gasket isn not high enough for the water to drian? anyone? bueller?
I also notice I clean up the water and then more water is falling from the soap dispenser when i pull it out. A lot of water is left in the soap dispenser when done washing also.
I have had this washer for 3 days now. my last samsung washer lasted for 20 years
Comments??
1 REPLY 1
Re: Samsung White Front Load Steam Washer - WF45R6300AW
Can I ask if the unit was professionally installed? If so, you could have the installation company out to double check the connections and hoses. Also, here is a link to some steps that might help: http://www.samsung.com/us/support/troubleshooting/TSG01000977/
