Highlighted
Samsung dryer leaking natural gas
JUMP TO SOLUTION
Has anyone else experienced a Samsung dryer leaking natural gas into  home when dryer is not running?
Since I purchased the dryer, it leaks natural gas into my home when the dryer is not in use.  I have made several warranty claims and it is still not repaired.  I checked all external connections for leaks and replaced teh hose from the wall to the dryer and verified that there was not external leak.  I submitted a warranty request with this information and when the service tech arrived, he checked the external connection and said that there were no leaks "duh".  I submitted multiple subsequent requests for service and they were all canceled by the same service company.  I also discovered that there are no other service companies that service my area.  I was finally able to get someone to open a product liability claim days after my warranty expired.  They authorized a one time service call to check out my dryer.  The same service company Cone Appliance Repair in Louisiana arrived but with a different technician.  He ordered solenoids for the gas valve and returned a few days later and replaced the solenoids.  He gave me his phone number and asked me to call him if I had any further issues.  I called him several times and received no answer.  I called Samsung and got in touch with a customer service representative that argued with me that the dryer was out of warranty.  I realize that the dryer is out of warranty but service was delayed several times by appointments being canceled and after several months, my dryer is still leaking gas into my home.  I was connected to another representative with the product liability department and they said that they opened a new case but I am not sure if they just told me that to delay again because I have not heard back from them after several emails to the representative.  So I am still stuck with a dryer that leaks dangerous natural gas into my home if I forget to close the supply valve after I finish a batch of clothes.  I purchased a natural gas detector and have plugged it into a receptacle in my utility room and sometimes it is activated minutes after the dryer finishes a cycle.  A good reminder for me to turn off the gas valve.  I am not sure why the valve was not replaced or at least checked for leaks. I guess it is not a cheap part and Samsung is hoping I just give up and either buy a new dryer or pay for the repair myself.
1 SOLUTION
Highlighted
Re: Samsung dryer leaking natural gas
JUMP TO SOLUTION
We are sorry to hear about this. Please send a recent ticket number, or the model and serial numbers, to this PM link, and we will look in to this.
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
This issue is happening for a second time in the three years I have had my Samsung dryer.  It seems to be a product defect that should be recalled.
Highlighted
JUMP TO SOLUTION
Finally I was able to get Samsung to issue a refund for this defective dryer!!!
