Samsung smart washer/dryer
(Topic created: 10-14-2021 12:53 PM)
kbprouty
Washers and Dryers
Hi, smart washer/dryer Says it will cease on oct 5 2021 that only the smart check is will work. Why are the other features not working and will there be another app to replace it?
Thank kristy
SamsungNik
Washers and Dryers
Hello, Yes it is correct the smartthings classic application will be experiencing some excited and new updates for consumers. You can find out if your model works with new and improved smartthings by looking up the model code. Here is the link for review- https://www.samsung.com/us/smart-home/compatible-devices/
kbprouty
Washers and Dryers
On sorry I'm not asking about smart things. I'm asking about smart washer/dryer app. The only thing that work for this app is the smart check in the app.
kbprouty
Washers and Dryers
Is there going to be an app to replace it?
SamsungNik
Washers and Dryers
Hello, I apologize for the confusion and I would recommend creating a Support ticket so we can look into your concerns further. You can reach out directly to a support team in your area using the below information:
phone: 1-866-813-2404
or
online at: support@smartthings.com
