Highlighted
Smoke inside Front load Washer
My Front Load VRT Washer ( WF338AAW/XAA ) has been noisy on the spin cycle for a few weeks.  Yesterday, I noticed alot of  unknown pea sized gray and white debris when cleaning out the filter despite cleaning it out a week ago.   I ran a load right after cleaning the filter and about 15 minutes into the cycle the inside had smoke.   Any thoughts?  A belt perhaps?  Or, the motor?  I am wondering if the debris was rubber from a belt?
1 REPLY 1
Highlighted
Re: Smoke inside Front load Washer
I do apologize for the inconvenience this has caused. Can you send me a private message with your full serial number? http://bit.ly/2tCGnGK
