- Mute
07-04-2022
12:10 PM
(Last edited
07-05-2022
07:05 AM
by
SamsungJecca
) in
Hello,
I am trying to find out if this washer : https://www.homedepot.com/p/Samsung-4-5-cu-Smart-High-Efficiency-ft-Front-Load-Washer-with-Super-Spe...
will be compatible with this dryer:
Solved! Go to Solution.
- Mute
07-05-2022 06:36 AM in
Washers and DryersThanks for clarifying! I have great news for you! According to our parts website (linked below) the stacking kit model SKK-8K is compatible with all 27" laundry units. This includes both the washer model WF45A6400AW and the dryer model DV42H5000EW from your original post. This means you absolutely can stack this dryer on this washer!
- Mute
07-04-2022 12:36 PM in
Washers and Dryers@userKmQlTG2BbJ What do you mean by compatible?
The two devices don't interact with each other. They each have their own separate job.
- Mute
07-04-2022 01:35 PM in
Washers and DryersSorry I should have specified:
I am trying to figure out if the washer I listed would be able to be stacked with the dryer I listed.
- Mute
