Highlighted
Re: Top load WA400 spins and rinses continuously
JUMP TO SOLUTION
@userQLPj0WczdT
Will you please send a private message with the full model code and serial number of the washer? Also, please confirm if this occurs when running an empty cycle.
http://bit.ly/2XERsky
Highlighted
JUMP TO SOLUTION
Had this happen to me, make sure you are using HE detergent and if you are try using less!! I was using too much and it was trying to rinse it out!! Hope this helps!! 💜💜
Highlighted
JUMP TO SOLUTION
Hello, my washer has this same issue and i learned of the recall WA400PJHDWR/AA. WIll the recall repair fix the DE out of balance issue? I cannot complete any loads without this occuring
Highlighted
JUMP TO SOLUTION
I would recommend reaching out to that department concerning this. You can reach them at 1-866-264-5636. Monday through Sunday, 8:00 am to 10:00 pm Eastern Time.
Highlighted
JUMP TO SOLUTION
My machine just started to do the same, can you help me?
Highlighted
JUMP TO SOLUTION
Could you send me a private message with the full model and serial number?
Highlighted
JUMP TO SOLUTION
My machine is doing the same after the recall fix, can you help me?
Highlighted
JUMP TO SOLUTION
Can I have your full model code and serial number via private message?
Highlighted
JUMP TO SOLUTION
Mine started doing the same thing recently.  The link from a while ago doesn't seem to work.  Is there an updated solution to this problem?  Thanks!
Highlighted
JUMP TO SOLUTION
My washer is doing the same thing. I've added foam between the frame and tub but it still spins out of balance and shuts down and starts adding water and rinsing. Can I get a recall repair?
