ajcboss
Re: Top load WA400 spins and rinses continuously
JUMP TO SOLUTION
Having the same issue with my WA545AN. Wash cycles down to 7 minutes and starts to spin. During this spin it seems to start off balance but gets smooth then starts another rinse cycle and goes from 7 minutes to 17 minutes. This spin at 7 minutes is the only spin that seems off balance. All other spins during the wash seem fine. Very tired of having to wring the water out by hand. We had the recall done on this one over a year ago. Any help for this??
JUMP TO SOLUTION
ajcboss, please send us a private message with the full model code and serial number: Link
Jsfshepherd
JUMP TO SOLUTION
I’m having this exact same problem. Washer won’t spin. Gets to 8 minutes, reverts to rinse cycle even if I’m on the spin only option. So much water and electricity wasted. I had the recall work done, though I believe that’s not related. This seems like a big issue with these washers...Samsung, will you help with a repair?
JUMP TO SOLUTION
userFCSQTS129S, please send us a private message with the full model code and serial number: Link
user9vf6P7QY62
JUMP TO SOLUTION
same issue, sent message to Gill.  see what happens.
Sean_T
JUMP TO SOLUTION
I am having the same issue, dc unbalanced then refills water and occurs repeatedly. Sending you a message Gill.
Sean_T
JUMP TO SOLUTION
Wow the moderator reply I received just said I am out of warranty and I need to pay to get it fixed, even though this thread says very differently and also my unit is on recall. What is going on here?
Sean_T
JUMP TO SOLUTION
Gill are you or any moderator still here?
JUMP TO SOLUTION
Our apologies @Sean_T. I have reached back out to you via private message. Please follow up with me there.
JamieDas
JUMP TO SOLUTION
Having an issue with my Samsung washer model no. Wa50f9a8dsp/a2 during spin cycle. It stops then refills with water constantly. Takes over 4 hours to do a load of laundry what do I do to fix this issue
