mn10
Re: Top load WA400 spins and rinses continuously
JUMP TO SOLUTION
We have the same issue. Sent PM to Gill...
JUMP TO SOLUTION
The troubleshooting for this issue can be found at this link.
pcamp96
JUMP TO SOLUTION
I just got this washer and dryer from a friend last weekend and am having the same issue. It gives me the dc error code after a wash, and when I try to run a spin cycle it adds water. I've tried to remove some of the clothes and redistribute before continuing, and it still does the same thing. Adds water in the spin cycle. What gives?
JUMP TO SOLUTION
Does this also occur when you run an empty cycle?
userCdOSRt4foV
JUMP TO SOLUTION
I am having the same problem. It looks like the recall has nothing to do with this spin problem. How do I get it repaired?
