- Mute
04-27-2025 06:26 PM in
Washers and DryersTop load washer keeps beeping but nothing seems to be stuck or jammed the lid closes but it keeps beeping and does not wash
- Mute
04-27-2025 07:33 PM in
Washers and DryersI recommend contacting Customer Service to schedule a technical visit. During the visit, they will be able to assess the issue causing your problem and determine the appropriate solution.
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
- Mute
10:42 AM
(Last edited
04-28-2025
10:52 AM
by
SamsungJustin
) in
Hello, SonimeD
I'm sorry to hear about the trouble. Before you go down the route of reaching out for service, are you receiving a message on the display screen?
Have you tried the following steps? https://www.samsung.com/us/support/troubleshooting/TSG01108862/
Let me know if this helps or if you're receiving a specific message.
