VRT Front loader will not wash - 4 "spinning" lights on LCD display?
(Topic created on: 2/15/21 5:04 PM)
userQ7SNHM7fQH
Washers and Dryers
WF45K6500AV
When I try to put it in a wash cycle, the door locks, the machine adds some cold water, then it does nothing but shows four spinning lights where the time left would be or an error code would display.  I have looked at error codes in the manual but nowhere is the spinning lights mentioned. I have reset the breaker, I have cleaned the drains, I have ensured the drain pipe is clear and flowing.  Please advise!
1 Reply
SamsungLou
Washers and Dryers
I am sorry to hear about this. Does this happen in all cycle selections? Have you tried running a Calibration on the washing machine?
