userXK7UcVF406
WF45H6300AW/A2 Front Load Washer Leaking
I've got a WF45H6300AW/A2 Front Load Washer that is leaking through the front door.    And of course were out of the 1yr warrantly.
It sounds pretty common.   Anyone else have this problem?
7 REPLIES 7
Re: WF45H6300AW/A2 Front Load Washer Leaking
Does there seem to be any damage to the gasket by any chance?
userXK7UcVF406
No, it just seems to not want to seal at the lower front of the glass.
userXK7UcVF406
Also, how do I find the complete model number to order a new part?
On the sticker inside the door I see WF45H6300AW/A2, but when I go to order parts there are different versions.  i.e.   WF45H6300AW/A2-01   or WF45H6300AW/A2-0000  or WF45H6300AW/A2-02  etc.   ??
userzkuNRLgG5D
Sounds like the gasket.. check for rips.. common cause is...
Sounds like the gasket.. check for rips.. common cause is zippers..
userXK7UcVF406
No rips, the rubber lip just isnt sealing.
@userXK7UcVF406 Because this is a front loading washer, have you cleaned out the debris filter and drained the emergency hose as well? If so, service would be recommended and you can locate a local service center at this link.
usero7Iji1bYfl
I have the same problem 5 days beyond the one year warranty.
