userBllhu9kySD
Washer door gasket for wf45k6500
JUMP TO SOLUTION
I am trying to find a gasket/seal for the foor on my Samsung wf45k6500av/a2 model washer. A parts place couldn't tell me the part number for this and could therefore not help me. Anyone know the correct gasket for this machine (6/2016) and/or where to get it? Thanks, Bill
1 SOLUTION
Re: Washer door gasket for wf45k6500
JUMP TO SOLUTION
Unfortunately we cannot provide parts numbers as these are subject to change without prior notification, and we don't want to give you a wrong part number. However, you are welcome to check www.samsungparts.com or you can call them at 800-627-4368 directly.
1 REPLY 1
JUMP TO SOLUTION
