Highlighted
Washer starts upon pressing power
On occasion, we will go to the washer after we believe it has finished a load. When we press the power button it turns on, flashes all of the lights, starts filling with slightest bit of water, then stops, and beeps a few times. This happens before we have hit any settings, or the start button. It will happen several times upon hitting the power button before we can change the settings and begin a new load.
1 REPLY 1
Highlighted
Re: Washer starts upon pressing power
To better assist you, please provide the model code of the washer. Is it leveled properly and have you flipped the circuit breaker off for a few minutes to "reset" the washer?
