user3YZ2N3RBG1
Re: Washer stuck in spin cycle WF45K6500A
JUMP TO SOLUTION
My washer get stuck at 8 minutes. It goes down to 5 minutes, stops, the screen goes blank as if it's done and then it comes back in at 8 mins. It never really spins hard enough to get all the water out of the clothes which increases the dry time. I see that this is a common problem. Is there a recall for this problem?
JUMP TO SOLUTION
@user3YZ2N3RBG1 Thank you for reaching out! I will be happy to look into this for you. Please send a private message with your model code and serial number. http://bit.ly/2XERsky
