Washer stuck on drain and will not switch to rinse and spin
(Topic created: 04-30-2025 04:44 PM)
CrudeLyric
Washers and Dryers
I have a WA45M7050AW/A4 washer. I have changed out the clutch cable assembly, the drsin pump and the pressure switch. It will fill wash and drain, continues to try and drain even after the drum appears to be empty. If i put a shop vac on the drain line i still suck out about 1/2 a gallon of water. The lines are clear and even running diagnostic mode it will pop up a 5c code during the drain cycle. What else can the problem be?
