Washer making noise when spinning
(Topic created: 03-24-2021 04:33 AM)
userM8JyeGtgyj
Washers and Dryers
Samsung direct drive washing machine
is making noise when spinning
MrLarry
Neutron Star
Washers and Dryers
Hey, give this link a shot: https://www.samsung.com/us/support/troubleshooting/TSG01001985/ If this does not help I recommend letting a service technician have a look. I will provide the service link here- https://www.samsung.com/us/support/service/ to proceed with out of warranty service.
You can also use any contact method listed below to reach us directly:
Facebook- https://www.facebook.com/samsungsupport/
Twitter- https://twitter.com/SamsungSupport/
Instagram- https://www.instagram.com/samsungsupport/
or
Private Message by selecting any moderator and clicking on the chat option with your full model and serial number, I would love to assist you further with this issue, if possible.
MrLarry
Neutron Star
Washers and Dryers
or
MrLarry
Neutron Star
Washers and Dryers
An Accepted Solution has been marked and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find resolutions and needed content. Remember that if you do make a post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring with your product. Thank you for being part of the community!
FrustratedinIdaho
Washers and Dryers
My Samsung washer model# WF45T6000AW/A5 has a noise during the spin cycle. This machin is 1.5 years old. I've spoke with Samsung about it. We done diagnostics on it and they've even connected to my phone's camera so they could see and hear what is going on. They sent out this "certified" repair company 3 times, replaced the shocks. And have tested on the rinse and spin cycle and says it runs great. That guy (and my husband) must be dead, because it's still making the same noise. Samsung also helped me calibrate it, still making the noise.
JBTechfanatic
Black Hole
Washers and Dryers
Banging noise comes from a couple things first putting too many clothes or towels in at a time .when wet it's extremely heavy so if this is off balance meaning there's more on one side than the other when it starts to spin the weighted size causes the drum to move extending causing it to expand to the Max and bounces back over and over essentially hitting every time. the next thing that causes noise if you have anything with buttons especially metal button Levi pants coins in the pocket Etc can Bounce Around the drum when spinning. So what you can do is never overload follow the exact specs listed in your manual also make sure when you load your washing machine you balance the clothes out Distributing them evenly in a circle if you have a front load washer lay the clothes evenly on the bottom portion flattening them out so when it begins to spin they can stay level as much as possible. and then of course making sure everything's out of the pockets no coins are in the drum or any metal. You might try running it empty and see if you hear the same noise if you do then you likely have a problem
FrustratedinIdaho
Washers and Dryers
I fill it 3/4 full. And it looks balanced to me. The noise is much more than would be for snaps or buttons.
JBTechfanatic
Black Hole
Washers and Dryers
can you post a clip so i can hear it?
FrustratedinIdaho
Washers and Dryers
Do you have an andriod phone and quick share?
FrustratedinIdaho
Washers and Dryers
It's a long video, but if you go to about 4 min 35 secs you'll start hearing the noise, then at 10 min 45 secs, it's done spinning.
