Highlighted
Washing machine drum filled with smoke
JUMP TO SOLUTION
My washer was not balanced during the spin cycle.  It was making a lot of noise.  When it stopped and I opened the door it was filled with white smoke!! It smelled like burning rubber.
Model WF501ANW
1 SOLUTION
Highlighted
Re: Washing machine drum filled with smoke
JUMP TO SOLUTION
Oh no! I apologize for the inconvenience this has caused. Please feel free to send me a private message with full serial number http://bit.ly/2tCGnGK
2 REPLIES 2
Highlighted
JUMP TO SOLUTION
Highlighted
Front loader washer — loud band and then smoke
JUMP TO SOLUTION
My less than 6 year old washing machine made a loud bang and then started smoking from behind.  I turned it off and opened the door and smoke came pouring out.  Can this be fixed or do I need to replace it?
Thanks
