Water Won’t Fill
(Topic created: 04-07-2024 09:00 PM)
Ss15
Washers and Dryers
Model: WA45M7050AW/A4
I ran the diagnostic (delay start 17 - AS) and the code displays Ot
I checked the water supply line, replaced the inlet valve and replaced the pressure sensor, but still no water fills when I run a cycle.
It does fill with water when I run the diagnostic but not when I run a cycle.
What is wrong with it?
1 Reply
GaryB82
Epic Samsung Care Ambassador
Washers and Dryers
I would suggest contacting Samsung support and have a technician come and diagnosis the issue since I can't find a error code listed Ot you can try to reset the washer by leaving it unplugged for about 10 mins
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
