Water not filling - WA45N3050AW/A4
(Topic created: 4 weeks ago)
userUauuEfaWYZ
Washers and Dryers
The washer powers on cycles the door lock and options for a wash then when it is ready to add water I can hear it click to it and then it shuts down and nothing happens.
SamsungStephanie
Washers and Dryers
I absolutely understand how frustrating that can be and would like to assist as best as possible. Is the washer displaying any blinking lights or error codes when this occurs? I located some troubleshooting steps here- Water Issues to give a try.
If the troubleshooting steps did not help and you are out of warranty, you can use this Service Link to find a service center in your area or private message me PM Link with your full serial number to review service options.
- Please Note: If you are having an issue replying with the private message link from the app, you can click on my name and select the "message" option as a method to contact me directly as well.
1 Reply
SamsungStephanie
Washers and Dryers
