user7fafXQX11A
What is the difference between Samsung Jet Stick VS 90 and VS 90 E vacuums?
Do both come with the spinning sweeper? Why is one cheaper than the other? Looks like the expensive one comes with a soft brush and the cheaper one comes with a turbo brush. Is that the only difference? Does the cheaper one also come with the spinning sweeper attachment? The product pages are confusing. Anybody from Samsung cares to explain? I am planning to buy and cannot decide as the product pages are awful.
PS: I cannot even find a Vacuum category for the support forums. So I am posting in Washers and Dryers. What a mess.
Thanks.
5 REPLIES 5
Re: What is the difference between Samsung Jet Stick VS 90 and VS 90 E vacuums?
The VS 90 includes the spinning sweeper attachment. The VS 90E does not have this function.
jhenion
Can the spinning sweeper attachment be purchased separately?  Is it possible to interface the sweeper attachment with the VS90E model?
No, you can not purchase it separately. And no it would not be able to interface between them.
You are very welcome!
Samsung_rYPQgJu
Ok thanks dear
