Highlighted
power issues
My washing machine WF45M5500 turns on when I hit the on button and during load up it will turn off and keep clicking like it wants to turn back on. Even when I get the machine started, right before it starts to introduce water it will turn off. Any suggestions that may help?
1 REPLY 1
Highlighted
Re: power issues
Take a look a the link below, it might be able to help you with this.
----> https://www.samsung.com/us/support/troubleshooting/TSG01203022/
If the link was not helpful then service is required. Below are a few service options for you:
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can private message one of our moderators with your full model and serial number to have service set up. http://bit.ly/33ipYnO
-If the unit is out of warranty, you can use the following link below to request service or contact our phone support line at 1-800-Samsung to have service set up for you:
https://www.samsung.com/us/support/service/
