userqlpfDKbzop
wa45m7050 and dv45h7000 How to turn sound on and off
JUMP TO SOLUTION
Neither manual is clear on how to do this. Does anyone know how? Thanks.
1 SOLUTION
Re: wa45m7050 and dv45h7000 How to turn sound on and off
JUMP TO SOLUTION
For the Washer, you simply press and hold the Extra Rinse button until the Sound off icon lights up. The Sound Off feature can be initiated in the middle of all cycles.
For the Dryer to activate the Sound Off function, press the Dry Level button for 3 seconds or until the Sound Off icon is lit.
3 REPLIES 3
JUMP TO SOLUTION
userqlpfDKbzop
JUMP TO SOLUTION
Thanks very much.
JUMP TO SOLUTION
You're very welcome! Smiley Happy
