wa50m7450a Won’t advance to next cycles. Stops randomly.
(Topic created: 08-30-2021 09:18 PM)
Washers and Dryers
I am at a complete loss. Washer was working fine then randomly it will just stop before a rinse cycle/spin and won’t do anything until you turn it off. If I run a quick cycle it will just continue to fill drain, fill & drain, over and over.
I have made sure the drain is clear and the water lines are correct. I don’t understand what is happening. I am so frustrated with this washer. If attached the last washing cycle it was showing when just randomly stopping.
it is a wa50m7450a
TheGalaxy
Neutron Star
Washers and Dryers
Unplug from wall
Hold power button for 1 minute
Plug and test
Washers and Dryers
Hello,
I followed these instructions and started a small load. Went through the wash cycle just fine but then suddenly stopped with 28 mins left in the rinse cycle and has not done anything for 15 mins.
I am so frustrated and annoyed with these machines.
Washers and Dryers
Really any help with this would be appreciated. I have tried everything I could find online and checked as many possible errors/blockage etc as I could. I am at a loss.
