Gear Fit 2 battery drain
SOLVED
Re: Gear Fit 2 battery drain
I went in the weather app settings on my phone. I turned off location and set update interval to 12 hours. Hope this helps.
Hey all,
I was having this same problem, and tried all the tricks including turning off WiFi, turning on Do Not Disturb etc. but nothing seemed to work. A couple of days ago I was searching through the settings and discovered that my display brightness was set on 7, so I backed it off to 3.. Now I seem to have limitless battery life..
[ Edited ]
Before almost returning this piece of technology, I gave it a second chance and installed R360XXU1APE4.
Screen brightness 3
Not using GPS or WiFi
Using only bt to sync with Samsung health
Not updated stock apps or firmware
AVS simple digital 24h BW screen
After 36hrs still displays 74% battery.
Also turn off automatic updates on gear app.
Hope this helps
Again, after 51hrs, still 61% so I'm thinking, must be firmware bug
Honored Contributor
Thanks for the update @Tamarus
Sounds like you might have a fix there!  ^_^
SamsungViv wrote:
Thanks for the update @userNVg2wW3BRI
Definitely a fix.
Today morning, just updated to the latest firmware available and battery drain started again.
Needless to say, I reinstalled old firmware again.
This time I have updated all apps but not firmware.
BT always on
Automatic HR measure
No GPS or WiFi
Screen to 3
 Still 90% after 10hrs and lot of notifications later.
Hope this helps.
Having same issue and it looks like your fix works.  I have one question though, how do you roll back the firmware?
Not applicable
I really feel like someone who tries to make everyone happy and im sick. of it when the favours not re turned I feel like less than a human beings
https://forum.xda-developers.com/gear-fit/help/to-flash-firmware-gear-fit-2-t3489544/page2
Zargalo post.
If it fails, try again.
Mine took 3 tries to flash the firmware.
Hope this helps
Honored Contributor
Sweet! Glad to hear that things are being fixed up.  ^_^
