Gear S3 Frontier Tizen 3.0 Battery Drain
Cosmic Ray
[ Edited ]
Got latest update to Tizen 3.0 Suddenly battery drains a lot faster compared to previous firmware based on Tizen 2.4.2.4.  Made sure all settings are identical and Tizen 3.0 is supposed to be a lot more battery efficient.  Anyone experiencing similar problems?
Re: Gear S3 Frontier Tizen 3.0 Battery Drain
I had same issues after update, but simple reboot (not factory reset but just reboot) helped me.
Cosmic Ray
As I said, reboot did noting to improve the battery drain (in my case)
Same issue. It's brutal.
Me too.  My watch has gone from using 2% per hour to 5% per hour with the same AOD watch face.
Useless.  Factory reset did nothing to help.
Same here. Previously would drain about 20% a day (AOD disabled), now draining about 50% a day. Worse battery life than my phone now! Can't even last 2 full days.
Same issue. Unusable device in this conditions
It blows my mind that Samsung can release 3.0 with all the fanfare about extending battery life when in reality it makes it so much worse!  Incomprehensible.
[ Edited ]
Could have know this would happen, and as from now i will never update samsung products when a newer version comes out.
I have seen this with the S6 S7 and Gear S3 now.. everytime samsung releases a newer version of a product an update will show up wich makes the battery drain twice or 3 times as fast.
Its nothing more then a trick to let people buy new products because old ones become useless.
Its becomming really obvious with samsung products.
My advice: dont update your samsung devices when newer versions of a product come on the market!
@samsung
Come on guys, battery issues?? You guys did not test this for at least 8 hrs? This is the worst bug on software found! I have the same problem,  after this update my battery is Terrible! Fix it please, or you guys will have increase of Returns. What is the quick turn around?
