Gear S3 connection notification
Re: Gear S3 connection notification
Thanks.
That doesn't seem to be available for Gear S3. Any advice?
Just to confirm were the watch, wearables app, and phone updated recently?
Having the same issue and it's driving me crazy! Definitely seems to be from a recent update, I've had the watch for a few months but only noticed this in the last two weeks.
Is both your watch and Gear/Wearables app up to date?
Yes, both are up to date.
Any idea who to solve this? Thanks.
Unfortunately, there isn't a way to disable the notification when the watch goes out of range.
Think I figured it out. When the notification pops up, click on it. It should take you to the galaxy wearable app. If you scroll down you will see "watch connection" and it will say "disconnected." click on that... You will see "receive a notification when a watch is connected or disconnected." turn it off!
