I'm not able to connect calls on my car on my Note 20 ultra
(Topic created: 10-22-2021 02:15 PM)
telomojo
Note20
I cant connect to calls on my car I think is the software I reset everything and nothing I need help
DanG92263
Sun
Note20
Check with your auto dealer to ensure you have their latest software version, please.
telomojo
Note20
I did radio is running great....after I updated my phone software it happened
DanG92263
Sun
Note20
I don't know what your car radio would have to do with your car being on the most current version. Usually, from time to time, as new software is pushed to your phone, the car's software needs to be updated also to make things work. Happened to me in 2017. Bought a new car in Dec 2016, BT worked fine. Three months later, I upgraded my phone, that had a newer OS version. The dealer upgraded my car's software, and it worked fine again.
briguy575
Note20
Try doing a network reset not factory reset
telomojo
Note20
I did everything same thing
briguy575
Note20
Try doing a reset on your cars navigation system menu sometimes that does it and not your phone this time
