Bluetooth Audio Delay
(Topic created: 10-24-2021 04:58 PM)
userlKRZlH3QIo
Qled and Frame
I just purchased 85" Class QN90A Samsung Neo QLED 4K Smart TV.  I have paired 2 different bluetooth devices and in both of them I have been experiencing audio delay.  Is there a way to fix this?  If there is could advise how this can be done?  Thanks.
SamsungStephanie
Qled and Frame
Hello, I understand how frustrating the sound delay can be regrettably the main challenge with using Bluetooth is that connections can disconnect or become unstable if there's some kind of disruption. I would recommend ensuring the devices are as close to the television as possible to prevent and interference with the signal/ connection.
userlKRZlH3QIo
Qled and Frame
I do not think the problem I am experiencing is distance related.  In both bluetooth devices. I am probable about 9 feet in front of the TV.
SHERMIN56
Galaxy
Qled and Frame
with Bluetooth there is always a delay, I believe you can match it up in your tv settings. If you go to your settings/sound/expert settings scroll down and you'll see digital output audio delay.
But your best bet is to use an HDMI cable to connect your soundbar...I have a soundbar and had the same problem and for me, Bluetooth sucked too much of a delay the HDMI is the key.
