Showing results forĀ
Search instead forĀ
Did you mean:Ā
7.0 beta battery drain
(Topic created: 12-09-2024 07:07 PM)
chas099
Cosmic Ray
Discussions
Definitely noticing excessive battery drain with the 7 beta.
youu
Supernova
Discussions
Have you tried clearing the cache, also report it to samsung
SubStrykerSCR
Cosmic Ray
Discussions
What is "App Booster"? 3rd Party app or are you talking about Ram Plus?
RedOregon
Nebula
Discussions
And how much extra time have you spent on the phone exploring new options and settings?
ohios-finest
Cosmic Ray
Discussions
This is probably the main cause. I've noticed a little hit to the battery but, nothing crazy. Unless I'm on it all of the time.
Oneops
Discussions
My battery use/drain has been exactly the same here.
ohios-finest
Cosmic Ray
Discussions
That's to be expected. Still a few more betas to go.
TodaysTech
Cosmic Ray
Discussions
I honestly haven't noticed a difference. I'm quite pleased with this beta as far as stability.
JD931
Halo
Discussions
Mine has gotten significantly better. Try running Galaxy App booster. It got updated for One UI 7
USBetaModerator3
Beta Moderator
Discussions
Hello @chas099 ,
Thank you for your feedback on battery draining issue.
To assist us in resolving this issue, we kindly ask you to submit an error report through the Samsung Members app on your device:
1. Open Samsung Members.
2. Navigate to One UI Beta Program > Beta Feedback.
3. Attach any relevant screenshots (if possible).
4. Ensure "Send system log data" is checked, then submit the report.
Important: Please submit the report within 15 minutes of reproducing the issue for accurate log data collection.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
